well i am into my 78 atc 90 motor and the LH oil case is fubar from PO jumping the chain. is there a difference in the early 90 cases from my 78 model. and what is the cutoff. my case is #1680109 this wold be the crank case not the outer case with flywheel and dual range. its actually ok
I did some searching here and it sounds like any 90 case should work. just want to confirm this is correct before i get one on the way.
