Thread: switch repair
    Mar 2007
    Texas
    5,045
    switch repair
    who else completely dissembles their switches and refreshes them on a trike rebuild? some say they clean it, but I actually completely tear mine down and do a complete rebuild of my switches to ensure they work like new.
    This is how far I take mine. I will even go so far as to unsolder, and re-solder fresh wire to the ends if needed so they work perfectly. I use die-electric grease on reassembly.
    ________________
    https://www.mikesatvfix.com
    Scootertrash's Avatar
    In the sticks
    4,638
    I do it, even the it can be a pain in the brass.
    Nov 2014
    Paris, Tx USA
    100
    In the process of doing this now. Engine kill switch is working but light switch is no-go.
    By the way, couldn't see your pic. Looks like link may be broken.
    Sent from my SM-G900P using Tapatalk
    Mar 2007
    Texas
    5,045
    weird on the pic, it was uploaded to 3ww
    ________________
    Jan 2014
    Massachusetts USA
    782
    Yup, I do the same. The feel of smoothly operating switches makes a big difference to me. Its the same reason I'm a lever snob- new levers and perches on every build, even brand new Parts Unlimited house brand OEM replacements are better than worn out stock ones. Controls and suspension are 50% of the overall riding experience in my book.
    1985 Tri-Z 250
    1985 ATC250R
    Oct 2008
    NB, Canada
    852
    I usually only would open up any of mine if there's an issue. I've opened a few and resoldered broken off wires. Opened key switches as well when they're not working, and cleaned the contacts, and reassembled with dielectric grease.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
