Thread: Wont stay in gear
    Dec 2012
    Newfoundland
    140
    Wont stay in gear
    Finally rebuilt the 250 timber wolf for my ytm 225 and now have all 5 gears working after a bad sprocket and shift fork...took her for the maiden voyage for a 2 hr run and ran good no issues.Parkes over night ( in heated garage) and the next day I didn't get out of my driveway and she slipped out of first into neutral...click up and back into gear again fine...but no matter the gear I'm in once load goes on her she slips to neutral. Any ideas?
    1985 Yamaha 200E -ForSale!
    1986 Yamaha 250Dr (beartracker swap)Forsale!
    2009 Sportsman 850Xp
    2014 Renegade 800r
    2011 Dodge Ram
    Apr 2014
    Edmond, KS
    2,591
    Is it really going into neutral from any gear or just a "false neutral"? A false neutral is when you get it in between two gears instead of really being in the neutral position. Is your clutch maybe out of adjustment? Is there a broken spring that is supposed to keep it in gear?
    Dec 2012
    Newfoundland
    140
    I'm thinking a false neutral clicks back into gear perfect and then slips out again..had side of case off to check shift drum and she clicks Ina and out there good by the look it it
    2014 Renegade 800r
    2011 Dodge Ram
    Dec 2012
    Newfoundland
    140
    just curious if the adjustment arm could affect this..dosent seem to have any effect adjusting it
    2014 Renegade 800r
    2011 Dodge Ram
    Dec 2012
    Newfoundland
    140
    Just pulled both clutches...everything looks good in that department...I'm lost at this point
    2014 Renegade 800r
    2011 Dodge Ram
    Pacific NW
    4,255
    I usually pick a keyword for the search feature and read anything similar, even different machines.
    Most gearboxes seem to have some sort of spring loaded 'detent' ball that kind of holds
    stuff where it needs to be.
    Odd that it worked fine for a couple hours and then decided to quit after a nap.
    Sounds like my luck.
    Then again, I had one funky shift 250sx and didn't realize that the shifter arm was dragging on the engine case.
    Shift arm tight enough on the splines to give it full throw?
