Results 1 to 2 of 2
Thread: honda 200x headlight won't work
    Nov 2015
    Miami, FL
    Hi,
    I recently purchased an 84, 200x. All is in working order with the exception of the front headlight. The bulb it has is brand new and I even attempted swapping bulbs with a friend. Not sure what else I should try in order to fix my problem. I don't know much about electricity so if anyone can give me some advice as how to walk through and test wires I would greatly appreciate it.
    Thanks,
    Jan 2016
    Arkansas
    56
    I know this is an old thread, but ill reply anyway, lol.
    Does the tail light work ? If Not then you prob need to replace your Lighting Coil.
    If tail light does work then remove your gas tank and check the wiring harness.
