I cannot seem to get gas to flow into the bowl from the tank. I have good flow out of the tank. I only have the reserve line hooked up at this time. Tried two different carbs with the same result, one brand new knockoff, the other the original freshly rebuilt.
Only using a small amount of gas in the tank.
ATC runs fine with gas being squirted into the carb inlet. I did this for about 15 seconds steady to see if engine vacuum would draw in the gas. No luck.
I tried cracking the bowl drain, no flow there.
Do both lines need to be hooked up?
Thanks!
