Results 1 to 15 of 54
Thread: Fixn to turbocharge my trike, for cheap!
    Oct 2008
    Reedsport Oregon
    856
    I was just about to rob a car in the junkyard of its turbo when a guy on a different site sent me this.
    http://www.ebay.com/itm/CXRacing-GT1...FS4iHc&vxp=mtr
    its cheaper than a aftermarket pipe and should produce a decent "boost" in power, i can weld er up so im going to go for it on my suzuki alt 160.
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    Scootertrash's Avatar
    In the sticks
    4,638
    I thought maybe you were gonna go with a reverse mounted Hoover
    Jan 2013
    minnesota
    5,911
    Do you know much about turbos?
    May 2011
    eden,ny
    3,481
    All I can say is good luck. Keep us updated.
    Mar 2007
    Texas
    5,045
    that turbo is gonna me way to big and the motor will not hardly push it.
    do a google search for 125cc turbo kit
    there is a place in canada that sells an entire turbo kit with EFI conversion and turbo and will set it up for a 2-stroke.
    4-stroke kit is $650 and +$150 for 2-stroke setup
    ________________
    https://www.mikesatvfix.com
    Oct 2008
    Reedsport Oregon
    856
    thanx for the heads up oscarmeyer, what yall think about this? its cheap and worth a shot imo
    http://www.ebay.com/itm/Motor-superc...BWMJeY&vxp=mtr
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Quote Originally Posted by hawaiirider View Post
    That's an electric hair dryer with a filter, Turbos work off exhaust pressure not consistent press; By using exhaust it increases pressure as RPMs increase. A constant press (Speed) of the rotor from an electric motor will cause it to be very lean at low RPM and very rich at WOT, that is if it will even run. I say give it a shot but know it is going to be a nightmare to tune and jet correctly if it is even possible.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Oct 2008
    Reedsport Oregon
    856
    they have sold alot of them? i can do the regular turbo. i would think the electric one would run off your ign system and rev rpms with the spark as it increases, otherwise it literally is a hairdryer and would not do anything!
    Jan 2013
    minnesota
    5,911
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by RUNMEDOWN View Post
    Its actually a fan, a hair dryer has heat.
    Jan 2013
    minnesota
    5,911
    They sold a lot of these too.
    "For less than $1.00 per tank of fuel you can realize savings of $8.00 to $10.00 per tank and more. 1 pellet treats 16 gallons of gasoline."
    Hey Barn...if you use 10 of those you will get 100 miles per gallon!
    Jun 2006
    Omaha Nebraska
    321
    Do you put those in the tank before or after the mothballs?
    Oct 2008
    Reedsport Oregon
    856
    lmao, knew the electric one was too good to be true, back to the 189$ real one on ebay??
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by oscarmayer View Post
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    U can turbo it but do you homework (a lot). Here's a pic of my best friends Raptor. It should be in the 220+hp range.
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
