Thread: Honda 200x help
    Oct 2013
    halifax pa,
    129
    Honda 200x help
    I have owned many 200x in my time and almost every one the frame broke at the front motor mount .Was wondering if anybody else has had this problem or am I just thrashing it to hard and if there is something to prevent this ? Thanks for your time.
    6,783
    Very common issue , weld a gusset their .
    Manheim, PA
    5,816
    The stock 200x frames are junk...plus add 30 years on a bad design and you will get failure.
    This is what you do to them front mounts and all the other locations that should be fixed up to ensure it does not break, bend or twist. If you need one fixed up strip the bike down and I will take it over to HRE who does all my 3wheeler frame work. I go there a lot and have my own project shelf there.
    www.HREatv.com
    Oct 2013
    halifax pa,
    129
    Thanks I will talk to you at the banks on Sunday
