Originally Posted by
barnett468
ok, your battery will not go from too dead to having enough charge to start your bike after it has run for 60 seconds, therefore, as El suggested you simply have a bad part or bad connection somewhere . . if i remember correctly there is a solenoid that gets sticky because the grease in it has dried up after 50 years and it will do EXACTLY what yours is and if you grease it or buy another one it fixes the problem, and i think you can check the solenoid with a volt meter when it is cold to see if that is the problem.
