Results 16 to 30 of 42
Thread: Current 350x project this winter, inspired by ATV on demand.
    devore,ca
    1,050
    Place you rear master cyl. in position and check to see if you can bolt up the break line. The gusset is usually in the way.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jun 2014
    Lengby, Minnesota
    31
    It is in the way a little yes but I'll make it work.
    Jun 2014
    Lengby, Minnesota
    31
    More progress Click image for larger version.
    Jun 2014
    Lengby, Minnesota
    31
    Swingarm & axle installed.
    Jun 2014
    Lengby, Minnesota
    31
    Triple clamps installed with bars
    Jun 2014
    Lengby, Minnesota
    31
    Front end is on suspension is upgraded with progressive fork springs and race tech gold valve emulators. Just need the rear shock to make it a rollerClick image for larger version.
    I also got bead locks and scorpion tires. The motor is being built now.
    Jan 2016
    Alberta, Canada
    25
    Lookin' good so far!
    Feb 2015
    new york
    86
    Looks awesome!excellent job.
    Oct 2014
    NEBRASKA,USA
    104
    Update on this? Im planning on doing this too if I get my 350x running.
    Mar 2014
    southwest indiana
    49
    this is gonna be a sweet ride. good for you! i had a hard time building mine back to stock, i wanted to replicate the atv on demand bike. im glad i went with stock though. my next one will be pretty tough though. good luck with the rest of the progress
    Oct 2014
    NEBRASKA,USA
    104
    Any updates on this 350x?
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    Quote Originally Posted by sunfire704 View Post
    You finish this build?
    Bump.
    Jun 2014
    Lengby, Minnesota
    31
    Yeah I kind of forgot about this site. I was new to it when I first starting building this. It has been completed for some time now I'll add a few pictures.
    1985 ATC 350x
    10.25 piston
    Ported
    5 angle valve job
    Megacycle cam
    DG krome/suppertrapp
    400ex carb
    Uni filter
    Jun 2014
    Lengby, Minnesota
    31
    Here's a picture
    1985 ATC 350x
    10.25 piston
    Ported
    5 angle valve job
    Megacycle cam
    400ex carb
    Uni filter
  15. #30
    Jun 2014
    Lengby, Minnesota
    31
    I added a harkabusic racing header now with a 400ex hmf silencer
ID:	241064   Click image for larger version.
    1985 ATC 350x
    10.25 piston
    Ported
    5 angle valve job
    Megacycle cam
    400ex carb
    Uni filter
