Results 1 to 15 of 50
Thread: 350x seized engine diagnostics
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    So, a few months ago I picked up a 86' 350X. Low hours, 90% original, don't think its been abused a day in its life. I picked it up cheap due to a locked up engine. The PO said he bought it like that and never got around to looking at it and had no clue what happened.
    Anyways,
    I bought it as a winter project and its bout that time of year. So im wondering, how should I begin diagnosing it? Pull the clutch cover and looking for a grenaded engine? What? I don't know squat about these monsters.
    Thanks,
    Daniel
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
    Sulphur Springs,Texas
    1,005
    looks nice, was that a local trike?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Scootertrash's Avatar
    In the sticks
    4,638
    I'd start at the top and work my way down. Pulling the head and looking in the cylinder can tell you a lot. It'll all have to come apart if it's the bottom end anyway.
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Quote Originally Posted by Hondatcs View Post
    It was down in San Antonio. he was selling it with a really nice 85' which I couldn't afford. He still had the other for sale last time I checked.
    That's kinda what I figured, really didn't want to pull the engine till I had to. They're heavy. I know that much.
    1,005
    Was the guys name Ernie.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    1,005
    Yeah I'm in the process of a rebuild and just like Scootertrash stated, I pulled the engine and started from the top down.
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    Miami,Fla.(305)
    808
    Before you pull it apart-pull the sparkplug and squirt some penetrate in the cylinder & let it soak a few days.
    The piston rings sometimes stick to the cylinder (slight rust from moisture) after sitting MANY years. It may/may not work but well worth a try. Make sure theres oil in the crankcase also. It looks like low hrs. on it so it might be just that.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    yeah, his name was ernie.
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Quote Originally Posted by 3wheelrider View Post
    Ok, Ill give it a shot, and yes, there was oil in the crankcase till I drained.
    1,005
    same 350x?
    • 1985 Honda 250SX
    • 1985 Honda 350X
    • 1985 Honda 350X
    • 1986 Honda 250R
    My Feedback Link!
    May 2015
    San Diego, CA
    1,789
    X 2 with the penetrating get oil.
    80% of all seized motors I freed up I did this way. That's what's up
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Just fill it with pblaster? and will I need to clean it out before I run the engine? If so how?
    Columbia
    5,131
    If the piston rings rusted to the cylinder, you will want to hone and re ring at the least. If you just free it up and run it, it will more then likely smoke. If not right away, eventually.
    I would do the pb blaster to get it free, then pull the top end to make it fresh again.
    Jun 2009
    Leander TX
    2,217
    Oil filter put in wrong and starved top end?
    Mexico
    9,014
    After the penetrant has done its thing don't try and free it with the starter, put it in gear and rock it back and forth first.
