Results 31 to 45 of 50
Thread: 350x seized engine diagnostics
  1. #31
    dman10's Avatar
    dman10 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2013
    Elgin, TX
    402
    Quote Originally Posted by 6spdls1z28 View Post
    Im really interested in what you find wrong in this thing.
    I am too lol.
    I've got the motor completely unhooked minus 3 of the motor mounts. Waiting for a second set of hands to pull it out. Those suckers are heavy.
    Quote Originally Posted by tri again View Post
    Cool stuff seems to happen when I'm sleeping.
    Nice to know things happen without me.
  2. #32
    Jan 2014
    Prescott az
    713
    Quote Originally Posted by dman10 View Post
    I am too lol.
    They are very. Reminds me of picking up a bare iron block v8 haha.
    [/SIGPIC]
    85 350x
    83 200x-sold
    ×2 85 200x-sold
    06 kx250f-sold
    86 tecate-sold
    86 tri z powervalved
    85 BIG red
    18 rmz250
    87 lt80
    19 ttr110
  3. #33
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Finally got it tore down, as suspected, piston was stuck, full of rust, not surprised with the mystery fluid in the exhaust pipe and the surface rust in the shifter side cover.
    But also found all the cool markings on the motor:
  4. #34
    Slidell, LA
    4,738
    what in the hell happened to that sleeve. You better call John Tice.
  5. #35
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    Our good friend H2O lol.
    Guess I'm gonna need his info lol
  6. #36
    Jul 2012
    Seattle, Washington
    1,543
    Im dealing with a similar problem but on a smaller scale:
    http://www.3wheelerworld.com/showthr...My-first-Honda!
    My odometer shows around 1200 miles, and was last tabbed in 1990. The valves were both closed but there was a lot of crap in the cylinder from a rusted out exhaust.
  7. #37
    Jan 2013
    minnesota
    5,911
    Did you get the cylinder off yet?
    PREVIOUS KAWASAKI INTERNATIONAL R & D PROJECT ENGINEER AND ATV DEPARTMENT SUPERVISOR
  8. #38
    Jul 2012
    Seattle, Washington
    1,543
    Quote Originally Posted by Jmoozy27 View Post
    Kroil is the #1 rusty nut buster for the oilfield worker in louisiana. With that being said, this advice sounds like a page out of the mechanical engineers bible. Barnett 3:68 "Thou shalt use only Kroil oil" (even as cologne) I'm glad it worked out for you Mil.
    Tell them Barn.... Preach the good word!
  9. #39
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
  10. #40
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    We also have a couple blued spots on the crank, everything seems smooth and tight though.
    I'd take a picture, but I couldn't get a good one in that bad barn lighting.
  11. #41
    Slidell, LA
    4,738
    If you are correct, and it did in fact hydro lock, there is no way the rod bearings are still good IMO. For s and g's grab he rod and pull up and down against the big end bearing. Should be zero up/down play. For a piece of mind I would get the crank rebuilt and get a new sleeve.
  12. #42
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    I'd love to rebuild it, but I don't have the place or knowledge to split the case.
    Here's the piston:
  13. #43
    Jan 2013
    minnesota
    5,911
    Unless I missed something, imo there is nothing that suggests it needs a new sleeve unless it is pitted too deep to clean up at 1 mm over . I would first remove the rust to get a better idea of just how bad the cylinder is pitted and then go from there . If it is beyond repair, you can get a used cylinder and bore that if it is much more cost effective than getting a new sleeve installed and you are on a budget.
    Here's a standard bore one for only $52.00 with the promotional discount plus free shipping and a 30 day return policy if you don't like it.
    http://www.ebay.com/itm/HONDA-350X-A...dYqlc1&vxp=mtr
    Here's one here for $80.00 plus shipping that looks like it should clean up with a bore with a 30 day return policy.
    http://www.ebay.com/itm/86-Honda-ATC...-/321160008894
    Here's several more.
    http://www.ebay.com/sch/i.html?_from...inder&_sacat=0
    If you want to go to a big bore kit you could call TC Racing and ask them what is available as well.
    http://www.tcracingengines.com/
  14. #44
    dman10's Avatar
    Jul 2013
    Elgin, TX
    402
    I've actually got a 85' parts motor, with a cylinder and piston I think that'll work, need to pull it out.
  15. #45
    Slidell, LA
    4,738
    You must not be looking at the same pictures I am. The sleeve is actually mushroomed in four corners unless its an optical illusion. That is toast.
