Results 1 to 12 of 12
Thread: 83 honda 200x fork seal replacement question
    Nov 2015
    Calgary Alberta Canada
    29
    Hey guys. I'm in the process of changing my fork seals and wipers.
    I emptied out the mud that the PO had been using as oil. Looked like melted chocolate ice cream all 3 tablespoons of it...
    So, got the snap ring out and pulled the tube like a slide until the seal popped out.
    Now for my problem...
    I cannot force the new seal in far enough to get it to seat. This is because I cannot get the slider bushing in far enough. Tried gently tapping around all sides of the bushing trying to get it to seat but it won't budge.
    If I turn the backer plate upside down I can get the seal in far enough to get the snap ring in.
    Will this cause any serious issues having the backer plate upside down?
    I figured I'd better ask now before I reinstall it.
    Any help would be appreciated. Thanks guys
    Oct 2014
    tn
    110
    Hey thunder I used a homemade seal setter out of PVC pipe. I just lubed it up couple small taps and was in. Hope it helps
    Sent from my XT1565 using Tapatalk
    Nov 2015
    29
    I've got no problem setting the seal. It's the brass slider on the fork that won't seat far enough into the lower fork tube. I just got home from work so I'll giver another go trying to get it in properly. Probably give it some heat and see what happens
    Surprise, AZ
    2,428
    Something doesn't sound correct.
    Please don't use heat, just grease the ID & OD of the DU slide metal bushing, drop it over the fork tube, then install the washer (Honda calls it a back up ring) then use your driver to tap it in until the bushing is seated, then grease the fork seal and drive it in, install the clip making sure it is seat all the way around, install the greased dust deal by hand.
    That's it, make sure everything is very clean before any assembly.
    Surprise, AZ
    2,428
    This maybe helpful if you are missing parts-
    http://www.partzilla.com/parts/searc...BER/parts.html
    Nov 2015
    29
    Thanks onformula. I got it all sorted. I'm working outside in an unheated garage. Guess it would be around 20 degrees out there. I just had to warm up the lower fork tube a little and everything went in smoothly. Got the new steering stem bearings in and got the tripples on the frame today. Just need to get the new bearings in the swingarm and I may have a rolling chassis soon.
    Jan 2014
    La
    1,062
    The 200x forks are literately hell to work on. I rebuilt one of my 200m shock no problem. But when I rebuilt my 200x shocks I broke more than I fixed in there.
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Quote Originally Posted by 86125m View Post
    Well that makes me feel good about this weekends project.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Surprise, AZ
    2,428
    If you run into trouble PM me I have those forks down to 20 minutes, tops plus cleaning time.
    Sent from my SM-G386T1 using Tapatalk
    Nov 2015
    29
    It wasn't bad at all minus the slider bushing. Most frustrating part is the snap ring removal. Get yourself a long 1 inch diameter brush and a jug of mineral spirits. Scrub and clean out everything. The second fork went much faster than the first. Get some 1 and 1/4 inch pvc to use to press the seal into place and you're golden.
    Jun 2006
    Omaha Nebraska
    321
    Just did mine 20 mins ago. The junk I poured out of the forks smells like the PO was riding in a pig farm. Nasty. But it had bushings and scrubbers that looked new. Just got done painting then the reassemble after paint cures.
    Mackus84's Avatar
    Mackus84 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2016
    Lakeland, Fl
    427
    I know this is a few months old, but im doing my fork seals now and wasnt paying attention on disassembly. Which way does the back up ring, and oil seal face?
