Results 1 to 15 of 18
Thread: Paint suggestions ??
    Sep 2015
    Western most part of N.C.
    53
    Any recommendations for possible spray paint matches for the Honda ATC tanks?
    Jan 2013
    minnesota
    5,911
    Exactly what gray on what tank?
    Williamstown PA
    5,825
    no spay paint..it wont last. powder coat it or buy a plastic tank and by decals.
    Michigan UP
    1,005
    I used sunset red I believe it was from rustoleum on a 70 tank and it held up just fine. Just let it dry for several days before putting gas in it. I also had the local auto parts store mix Honda Passion Red and put it in a spray can, it is the same paint that is on a car, not cheapo stuff. I paid $15 for a can from the parts store and then a can of clear for the top coat, came out nice and very durable.
    Sep 2015
    53
    ??? Metal tanks are spray painted from the factory bro. I have sprayed them myself as well. Not sure what u are speaking of?
    Sep 2015
    53
    Huh??.....
    Sep 2015
    53
    This is a 84 200M..and thanks briano for the paint info
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by dwil4 View Post
    Huh??.....
    lol, i was on my cell phone when i posted and the word spray looked like gray.
    Jan 2013
    minnesota
    5,911
    spray can paint is lower quality than the factory paint, plus most factories used catalyzed paint or lacquer which is many times more durable than spray can paint.
    Sep 2015
    53
    Right. U need a good clear like say spray max 2 part which is resistant to oil and gas..
    Williamstown PA
    5,825
    Just use a plastic tank or have it powder coated. It will be nicer. I know what I'm talk about lol.
    http://www.ebay.com/itm/NEW-80-84-Ho...O9748Q&vxp=mtr
    Why would you just not spend $100 and do it right, never have rust again, never have dents again, never have hurt knees again, never have crap from your tank get into your carb and motor and never have to paint it again.
    did I say "never" have to do anything but put gas in the tank?
    Miami,Fla.(305)
    808
    [QUOTE=oldskool83;1391155]Just use a plastic tank or have it powder coated. It will be nicer. I know what I'm talk about lol.
    If only those 185/200 plastic tanks werent shaped so hideously.-IMO-it would be great.
    My buddy has one for his 250ES thats the same shape as OEM- those were made nice.
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Oct 2013
    halifax pa,
    129
    I swear some people have nothing better to do than stalk this page and think they know everything then when you show them they r wrong no comment. Well anyway if you paint the tank the way you should and use good primer and paint take your time I've painted many thanks and look great and last .I also agree those plastic tanks just don't look good. Some people don't have the money to buy 200 dollar plastic tank when for 60 you can put a little work in and make it much nicer.
    Jun 2009
    Leander TX
    2,217
    I painted this 70 tank and forks with Summit Racing's single stage red poly.
    Not an exact match - but can you tell? I could not without another stocker right next to it.
    I used the same paint on my 350X frame. I'm impressed with it's shine and durability.
    Dec 2012
    812
    ...Why would you just not spend $100 and do it right, never have rust again, never have dents again, never have hurt knees again, never have crap from your tank get into your carb and motor and never have to paint it again...
    Ummm...because those plastic tanks take away from the authentic look of a vintage Honda 3 wheeler?
    1985 Honda ATC 250ES
    1985 Honda ATC 250SX
    1984 Honda ATC 200M
    1983 Honda ATC 200
    1984 Honda ATC 110
