Back in the day I never built a 350x full race bike, and as far as I know no one has since. Back then we didn't have low profile fenders, but now I do.
We didn't have a short track tank so you could really back it in to the corners.
I have just started building a short course tank based on the 85'-86' 250r tanks using the shrouds off a stock style tank to get more are to the 2 oil coolers.
This bike will be built to the rules for the Vintage class where we can only run up to .080 over in the stock cylinder. This will also be able to run in the new 200cc 2 stroke/ 350 4 stroke class, and the pro class if the customer wants to.
Getting the weight down is one of the goals which won't be much or easy because most of the weight is in the engine. I can get rid of 1st gear, the counter balancer, lighten and balance the crank and fly wheel, but other then that 10lbs I might cut the fins for more cooling mainly like the porky pine style cut I did on one of my 200x's.
I'm not sure where I'll end up on the swing are but I'm going to start with a plus 2 Cal-Fab and go from there. It will have a 10 inch front wheel and I'll just have to play with rear tires and sizes.
It's going to be a timely project over the winter months, but a fun one to see what a 350x can do.
DO the Best With What you got !
My Feed back :cool
