Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 84
Thread: Building a old school 350x TT racer.
  1. #31
    Jan 2008
    nc
    734
    What is your plan for lowering the rear?
  2. #32
    Hyndman PA
    1,905
    Quote Originally Posted by devilman View Post
    We have a works shock and I'm going to put a zero pre load spring on it so I can back the spring off as much as I want and the clip won't come off, it will always have pressure on it. It also has a 2 inch longer Cal-Fab swing arm.
  3. #33
    Hyndman PA
    1,905
    Two things that will keep you from winning races. One you push the shift lever under the case with your foot so you can't shift. The fix is to weld a washer on the top so it won't go under the case, simple fix. Next your seat falls off. It's real easy when racing for your seat latch to move around and un-latch it's self. I seen this at the first 3 wheeler race at Bedford proving grounds I went to last year. The racer was gaining on the leader and his seat popped off. Try riding the last few laps of MX with out a seat! Simple fix, two long bolts stuck down through the seat nubs and welded on to extend down below the rubber seat grommet with two wing nuts drilled to hold a spring and it won't happen again.
Name:	2006-01-05 04.32.47.jpg
ID:	227786Click image for larger version.
Name:	2006-01-05 04.33.15.jpg
  4. #34
    Jun 2004
    Oregon
    1,784
    Quote Originally Posted by Mickey Dunlap View Post
    Heck. Mines fallen off at the dunes many times lol!
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
  5. #35
    Surprise, AZ
    2,428
    Mickey, what did use use for the washer....it looks familiar.
  6. #36
    Hyndman PA
    1,905
    Quote Originally Posted by onformula1 View Post
    I think it was a stock Mojave 250 axle washer to hold on their rubber hub cap if you will.
  7. #37
    Hyndman PA
    1,905
    Piston's are done!
Name:	2006-01-14 04.36.58.jpg
  8. #38
    Oct 2006
    Wapakoneta
    815
    Better buy one d*** good decompression cable. My 425 is a pain to kick over, and I'm nowhere near that high of compression.
  9. #39
    Hyndman PA
    1,905
    Quote Originally Posted by xrider View Post
    I have built 13:1 530's and as long as you understand how to kick them they start easy, but every once in a while they will bite you!
  10. #40
    Oct 2006
    Wapakoneta
    815
    Yeah as long as you let the kick start roll completely back off the decompression than it is a breeze.
  11. #41
    Oct 2014
    NEBRASKA,USA
    104
    Is there an update on this? And do u still make the fiberglass rear fenders for the 350x or the 250r?
  12. #42
    Lewiston, N.Y.
    1,479
    Thanks for the update Mickey! Any more pix to tease us with?!
  13. #43
    Hyndman PA
    1,905
    Well it took 30 years to build the first 350x short coarse gas tank nick name the 350rx tank.
    In the old day you went into the first corner wide open and pitched in, but just because I built it, will he use it? The question is, will "Ditch Pitch it" !!!!!!!!?
Name:	2006-04-21 20.35.45.jpg
ID:	233220Click image for larger version.
Name:	2006-04-21 20.19.33.jpg
ID:	233221Click image for larger version.
Name:	2006-04-21 20.20.04.jpg
  14. #44
    Wichita, Kansas
    1,361
    I'm not to late am I?
    I love where this is going, just read through the last few pages.
    I've never owned a 350x, but let me through some ideas out there. <-- makes me sound credible right? :-D
    As for weight reduction, has anyone attempted an aluminum frame? I know Yamaha switched some dirt bikes over in recent years. With the correct engineering, i don't see it being to much of a problem. There would be some inherent flexing I'm sure.
    Aftermarket swing arms for other machines have been tubular, they look like they would weigh less.
    Everything else i'm thinking off wouldn't contribute much weight individually, but may add up. The list is to large to start and I'm sure it doesn't need to be stated.
  15. #45
    Jan 2015
    LaGrange, OH
    253
    That's the coolest 350 tank I've ever seen! Can't wait to see the bike together! Good work as usual Mickey!
