Page 4 of 6 FirstFirst ... 2 3 4 5 6 LastLast
Results 46 to 60 of 84
Thread: Building a old school 350x TT racer.
  1. #46
    Freedom Township, MI
    642
    Quote Originally Posted by RubberSalt View Post
    I'm not to late am I?
    Attachment 233225
    I love where this is going, just read through the last few pages.
    I've never owned a 350x, but let me through some ideas out there. <-- makes me sound credible right? :-D
    As for weight reduction, has anyone attempted an aluminum frame? I know Yamaha switched some dirt bikes over in recent years. With the correct engineering, i don't see it being to much of a problem. There would be some inherent flexing I'm sure.
    Aftermarket swing arms for other machines have been tubular, they look like they would weigh less.
    Everything else i'm thinking off wouldn't contribute much weight individually, but may add up. The list is to large to start and I'm sure it doesn't need to be stated.
    Usually the least expensive method to lose weight is if the anchor on top of the seat drops a few pounds! Not saying that's the case this time but I've seen some people drop some serious money on weight savings for their machine when they could have went on a diet and dropped 50 pounds themselves!
    Love the tank Mickey! I like the look of the R scoops better and you get still get OEM ones brand new!
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    2003 Polaris Predator 500
    1988 Yamaha Warrior
    2003 Polaris Predator 90
    Previous Trikes:
    84 Honda 110 (parts)
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    KX 80 Trike conversion
    Gone and missed:
  2. #47
    Hyndman PA
    1,905
    Attachment 233225
    The frame is one of the lightest out there already, a aluminum frame may save 2-3 pounds. It does have a Cal-Fab aluminum swing are going on it, but it's really the engine that weighs so much and the most I can lighten it is 2 pounds in gears and fly wheel. It is what it is. The tank is a lot lighter then the aluminum one I seen at Trike Fest. This one will keep it at least 7 pounds lighter because you can't fill it up with another gal. of gas. lol
  3. #48
    Hyndman PA
    1,905
    Quote Originally Posted by Matt85'350x View Post
    The good news is I don't have to drop the 100lbs. I would need to get to race weight because Bryan Ditch only weighs 170 or so.
  4. #49
    Hyndman PA
    1,905
    I know I know, I said I was putting the front end on the 350x TT racer Sat. , but after 8hrs of buffing the triple clamps and forks and I was getting ready to bolt it together I lost my balls! Any one know the first thing you need to put the triples on is your balls. Took me two day of searching for them until I went and found some balls at ACE Hardwear. "ACE is the place", so I got it together today! If it keeps going like this it's going to be a long build!!!!!!!!!!!
Name:	2006-04-25 22.02.17.jpg
ID:	233332Click image for larger version.
Name:	2006-04-25 22.02.34.jpg
ID:	233333Click image for larger version.
Name:	2006-04-25 22.02.44.jpg
ID:	233334Click image for larger version.
Name:	2006-04-25 22.02.58.jpg
  5. #50
    642
    Looking good, are you running dual coolers? Where is the coil going to mount? Why not run the tapered bearings?
    Current Trikes:
    85 350x
    P3 (x2)
    Quads:
    1988 Yamaha Warrior
    Previous Trikes:
    85 Honda 110
    85 Honda 200x
    87 Honda 200x
    85 Honda 250sx
    Gone and missed:
  6. #51
    Hyndman PA
    1,905
    Yes, we need cooler oil to the head, the highest wear area. I'll make a new mount for the coil. No time to order stuff, the race is in 9 days.
  7. #52
    Lewiston, N.Y.
    1,479
    No frame gussets?
  8. #53
    Hyndman PA
    1,905
    Quote Originally Posted by userj8670 View Post
    No frame gussets?
    It's for flat track racing only.
  9. #54
    Jan 2015
    LaGrange, OH
    253
    Update?
  10. #55
    Hyndman PA
    1,905
    Quote Originally Posted by 350xtrike.rider View Post
    Update?
    Yea the update is it's fighting me all the way, 2 days to build a rear lowering kit, front brake caliper another full day. The 300ex axle is going to be a all day job machining it to line up and the motor still isn't in it and running. I have 48 hours to get it done. This is what happen when you start with the nastiest 350x Bryan Ditch had and try to build the best trike you can.
Name:	2006-01-01 00.08.53.jpg
ID:	233512Click image for larger version.
Name:	2006-01-09 17.04.44.jpg
ID:	233513Click image for larger version.
Name:	2006-01-09 17.05.19.jpg
  11. #56
    Mar 2007
    Texas
    5,045
    Mickey, I am running the same axle and setup on the rear as you are. instead of machining all those extra stuff, I went ahead and just made 4 round collars that are .5" thick and drilled a hole in the center. now all I have to do is find 1/2" longer bolts to bolt the sprocket on and I am done. it will hold w/o any issues. this has been proven on many 350Xs running dunes and drags and such.
    just an idea to help speed it up.
    ________________
    https://www.mikesatvfix.com
  12. #57
    Hyndman PA
    1,905
    Quote Originally Posted by oscarmayer View Post
    Thanks but I can't chance that on a race bike.
  13. #58
    Jan 2015
    LaGrange, OH
    253
    Im dieing to see it!
  14. #59
    Hyndman PA
    1,905
    I worked so many hours on it only to come up short with a problem I haven't figured out yet so I didn't get it done.
  15. #60
    Jan 2015
    LaGrange, OH
    253
    Quote Originally Posted by Mickey Dunlap View Post
    That sucks....
