Thread: 110 vented case
    May 2014
    Mendon Illinois
    38
    110 vented case
    Has anyone ever drilled and tapped a 90 degree brass fitting right below where the oil dipstick is and ran a hose off of it to remove some crankcase pressure? My 110 is building quite a bit of pressure in it due to being 56mm, full race cam, ported head, and ported intake manifold.
    85 Honda 350x
    85 Honda 350x
    85 Honda 350x
    86 Honda 350x
    86 Honda 200x
    85 Honda 200x Hybrid (350x Suspension)
    84 Honda 200s
    78 Honda 110
    RIDE RED!
    Cold Lake, Alberta, Canada
    3,013
    I drilled out the centre of a dipstick slightly offset of the stick portion, threaded in a brake bleed screw and ran a clear hose way up into the frame. Poor mans venting but it worked.
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    May 2013
    Brownsville, Tn.
    1,271
    Here are some common vent locations........
Name:	VENT LOCATIONS.jpg
    * Nicholson 500 Race Bike *
    San Marcos Ca.
    709
    Hey is me our is that trike getting shinier every time I see it ?
    * 1970 US90 Red
    * 1985 ATC 200s
    Mar 2007
    Texas
    5,045
    I second the valve cap vent on the top. we used to run the Chinese clone motors of the 110 engines for my son's racing. drill a hole and run a 3.8" 90* barb off the top valve cap and your set. just connect a hose and plum to a T that goes from the crank case and your done.
    ________________
    https://www.mikesatvfix.com
