Results 1 to 15 of 22
Thread: 247cc ATC70
    Feb 2003
    Australia
    927
    247cc ATC70
    Finaly got my new laydown 247cc ATC70 bottom end together.
    CRF230F 70mm stroker crank, 200x cases with forward kick, CRF230F high volume oil pump, CRF clutch drive gear mated to the 200X clutch basket. Just waiting on a CRF cylinder to arrive and then be bored to 67mm with a forged Wossner piston kit. A performance CRF cam and CRF head will then be modified to run the 200X spark advancer and it should be good to go. Should be nice and light with no starter motor, battery and wiring harness.
    Ripley Tn
    1,363
    another monster coming from you
    85 Atc 70
    86 Atc 125m
    85 atc 350x
    86 atc 250r
    86 Atc 250r TT build
    85 Big Red bought brand NEW
    2012 Honda Goldwing Gl1800
    Nov 2006
    southern oregon
    2,338
    Sounds like a good time
    2-stroke lover
    Jun 2013
    Oceanside, CA.
    612
    You have some great skills there, modifying parts and building unique projects, some I've read in the past, but only could be better with pic's or a build thread.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    tecaterob is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2008
    Miami Fl
    435
    Dam little thing is going to be fast.. Can't wait to see the build thread.
    3 86 Tecate 3
    1 87 tecate 3 (with kx 540 motor)
    1 87 tecate 4 (with 330 motor, 250r geometry)
    1 83 atc 70
    1 Kfx 50
    1 kfx 400 ( with 470 parting out bike)
    1 78 KZ 1000 ( with 1340 turbo)
    1 Aprilia SXV 550 Supermoto
    1 01 ZRX 1200 prostreet (sold)
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by HairyJR View Post
    Hell yeah!!!
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Feb 2003
    Australia
    927
    I'll get some photos up later today my time.
    Pacific NW
    4,255
    Makes me want to do something with my lil' 70.
    Thanks
    wales..uk
    1,318
    we need pics man
    Need Honda ATC TRX NOS restoration parts??? or come check out our ATC brochure site
    www.offroadvintage.com
    Mar 2013
    Baldwin, Wi
    603
    Suspended?
    85 Tri-z Basket Case
    Newfoundland
    5,280
    C'mon with the pics!
    TTown, Alabama, United States
    845
    Just how fast do you need to flip over backwards?
    Should be great entertainment
    I cant wait to see this!
    Suicide Hill Survivor
    The rides:
    1981 ATC110
    1982 ATC185
    1983 ATC185s
    1984 ATC200es
    1985 ATC200x
    When the going gets tough, the tough get sideways
    Mar 2013
    Victoria BC Canada
    32
    Watching closely!
    Feb 2003
    Australia
    927
    Frame mods almost finished. Front engine mount and 110 axle and carrier next.Click image for larger version.
ID:	224827Click image for larger version.
    Feb 2003
    Australia
    927
    I have been looking for a sensibly priced CRF230 performance cam with no luck. I wanted to use this in my laydown 247cc ATC70 engine. It has a an ATC200X bottom end with a CRF230 70mm stroker crank and a 67mm CRF230 top end. I intended to add an advancer shaft to the CRF cam as I am using the 200X bottom electrics and flywheel. I have a few 200X aftermarket cams so what I did today was machine off the 200X bushings and sprocket mount and replaced all that with the CRF bearings and sprocket mount.
ID:	225674Click image for larger version.
