Does anyone know where to get a M3-0.5 screw? I need it to adjust my cam chain, as it is chattering a bit.
Thanks
Thanks
1981 HONDA ATC185S - parts
Da velder
Feedback:
I use the tail light screw from 200x
I see you're in Canada, I got one at Kent's once.
I've never had good luck adjusting my timing chains like that, mine were always so wore out it never made a difference. Usually once you have to adjust them with a screw they're basically at the end of your life, and you're squeezing just that little bit more out of them.
Rides:
1985 250sx
1982 ATC185s
1984 200es
Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
"Wear Limits Are Just A Suggestion"
