Thread: Air fooler pre purchase
    May 2014
    Mendon Illinois
    38
    I am looking at a 1st gen 250r basket case, it is not complete. Mostly there though. Dg pipe, 34mm carb and other stuff. Whats it worth? Are they reliable? Fast? How hard are they to rebuild?
    All help appreciated!
    85 Honda 350x
    85 Honda 350x
    85 Honda 350x
    86 Honda 350x
    86 Honda 200x
    85 Honda 200x Hybrid (350x Suspension)
    84 Honda 200s
    78 Honda 110
    RIDE RED!
    nicker71's Avatar
    nicker71 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2003
    Wright City, Missouri
    385
    A first gen in decent shape would be worth 700-900$ range IMO.
    They're quite simple motors to work on and reliable if they're air tight and jetted correctly. The drawback of the first gen is the lack of suspension travel. They're quick, but lack the top end speed vs the 350x and 3rd gen R.
    A pipe, larger carb(34mm-38mm) and high performance reeds will really awaken the power potential vs the stoxk components.
    Oct 2008
    Reedsport Oregon
    856
    there great trikes!! small and easy to wing around. suspension is kinda short, but good. motor is reliable and puts out good power. beat a 350x repeatedly in drags and climbed steeper dunes. they go for around 5-700$ where im at in good running cond. id leave it bone stock (reliable) and put a better rear shock on it, front aint bad!
    https://www.facebook.com/photo.php?v...90459716899181
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    Jan 2013
    minnesota
    5,911
    fast is a relative term and if it is not fast enough for you, you can modify the engine.
    easy to rebuild is a relative term . . the engine is easy to rebuild if you know how to do it . . if you don't, but are patient and mechanically inclined and have done some mechanical work before, you can do it if you follow the service manual.
    if you have never done any mechanical work, i would get some help.
    its often cheaper to buy one that is in very good condition than it is to build a basket case.
    Michigan UP
    1,005
    What do you consider fast? If maintained, anything can be reliable. Ease of repairs, what is your skill level? If was worth it, you'd already own it. There is no set value for anything really, something is worth what someone will pay. If the seller wants $500, I'd tell him to keep dreaming while the next guy might now believe the awesome deal that he got.
