Results 1 to 3 of 3
Thread: Big red 250 Gasket question
    wellys88 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2015
    WA
    194
    Im rebuilding a 1985 250 ES motor, on the listings for gasket kits some list as fitting 86-87 and others 85 only, is there a difference in the motors for the 3 years, I have 2 motors ES 250 and the shaft that the oneway clutch sits on is different size on both motors but everything else looks the same, I will run serial numbers to see what year, dont wanna buy wrong gasket kit, thanks
    NEPA
    7,051
    Only difference in gaskets I can think of off the top of my head is the starter reduction gears cover.
    Nov 2015
    WA
    194
    Thanks alot atc007, I ordered the set anyway, the splined shaft that the one way clutch bearing sits on is different size on both motors, just threw me off a bit when I saw that, thought there might have been some differences I did not know about, its the first time i have had one of these engines apart, serial numbers both say 85 250 ES unless if im not mistaken
