Results 1 to 10 of 10
Thread: Hi all new to group got a question about tri zinger
    Dec 2015
    Atlantic NC
    3
    Looking for some rear axle spacers or extended axle for 85 tri zinger...im building a hopped up zinger for my twin 6 year old boys...already have a test of raised renthal bars want put a pipe on it and eventually make it a 2 speed but right now just looking for the axle spacers....any help would be awesome i have looked everywhere....going for a mini 86 250r look....gonna paint plastics red have a new yamaha blue seat cover on the way...looking at getting some chrome rims for go kart but the same bolt pattern ....want a flat track tire ....mostly sand on outer banks of nc where we ride...lime i said new here any info my # 2527251808....just incase i cant find the response on here please text thanks guys
    Dec 2015
    East Kingston, NH
    91
    Sounds like you might be better of making your own and extending the lugs....A company call Mcmaster Carr sells plastic composites stock that could be made to work....I had similar plastic extensions on my 200x back in the day. I believe it's polythylene (HDPE) Have a good day.
    Jun 2014
    Pittsburgh
    107
    The problem with an extended rear axle on a tri zinger is its shaft driven. So you cant get extended swing arms or anything for it. I could be wrong but I think the hubs might be welded to the axle so you can't put different hubs on it like you could on a bigger trike. You could maybe put spacers behind the rim but you would have to change the lugs out as they are barely enough threads for the bolts already. Another thing is most zingers I see have a weld were somebody fixed it because the wheel hub broke and fell off. Widening its stance will increase this probability. And as far as I know nobody sells aftermarket pipes for a zinger so that would have to be a cut and weld custom job. Zingers aren't really aftermarket friendly at all.
    '' Mixin gas N haulin _ss''
    1985 250R-310
    1985 Tri-Z
    1985 Tri Zinger-X's 4
    1973 atc70
    Jun 2009
    Leander TX
    2,217
    DG made a pipe - might be worth pinging them - they sound great!
    http://dgperformance.com/dg-performa...odType=Exhaust
    rayatc84's Avatar
    rayatc84 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2010
    France
    194
    Mine with 70 Malossi kit + high compression head, DG pipe and extended hubs (+55mm each; built by a friend following my plan).
    Outside of engines with holes that stink, there is no salvation...
    My feedback thread: here!
    Want to see overseas 3wheelers? http://www.passion-atc.com of course!
    YT60 Tri-Zinger, YT70 Tri-Zinger modified, '84 ATC 70, '82 ATC 110, '82 250R, '82 250R modified, '84 250R, '84 480R in build, '85 310R, '86 250R, '87 250ES BigRed, '84 FL250 Odyssey, '85 FL350 Odyssey
    Dec 2015
    East Kingston, NH
    91
    Very nice hub ext....
    '85 ATC350X
    '85 ATC110
    '85 ATC200X (gone)
    '84 ATC125m (gone)
    '86 Tecate 250 (gone)
    glendive, montana
    1,822
    the dg pipe is not that hard to find, however I've thought about the hub spacers, but with as this as the axle is I worry about the strain it will put on it, but with the weight of a 6 yr old it shouldn't be that bad. even still I wouldn't recommend much jumping with them. the stock jetting needs to be reduced for maximum performance as well, but leaving it stock will prevent them from opening it all the way up till they are ready. also why paint the plastics when you might be able to find stock red ones for it.
    Dec 2015
    Atlantic NC
    3
    Awesome red bike man thats what im going for....and as far as painting it it vs. Red plastic it was just cheaper for me ...im just trying to fix it like my 86 250r ...because the boy wants his to look like dads ...so far i got some 7 and a half inch wide kart rims and just redrilled the bolt holes got a set of fly handlebars with new risers...got a new pw50 ignition coil...found a blue yamaha seat cover and got some itp mini holeshots ill get some pics up soon
    Jun 2014
    Pittsburgh
    107
    You already have the blue seat, paint the rims gold just like a 250R!!! Just throwing it out there. And yeah if you can find a pipe and muffler your going to have to re jet it. My daughter has a pipe that wraps around the side of the motor instead of underneath the bike just like a big bike. Also has a muffler on it but it needs jetted because my other daughters zinger with stock set up is faster???? It runs strong until heavy throttle then the fuel can't keep up.
    1985 250R-310
    1985 Tri-Z
    1973 atc70
    Oct 2014
    Upstate NY
    46
    I listed Zinger wheel spacers in the 3WW store in case anyone was trying to find some.
