Results 1 to 12 of 12
Thread: Octane rating?
    Oct 2015
    Polk City, Iowa
    27
    Octane rating?
    Will it hurt, help, or make no difference if I were to run airplane 110 or VP 110 in my 250R? I usually run the 93 ultimate from BP with a little octane boost and of course my Amsoil.
    Sent from my SCH-I545 using Tapatalk
    Current and only: "Beater" 1981 ATC 250R
    Love riding, wrenching, and fabricating.
    Williamstown PA
    5,825
    Does it have a high compression motor...high octane is only for built high compression motors.
    Jan 2014
    La
    1,062
    Just ask my cousin about race gas in a basically stock 250sx. It made the engine run so hot it melted his mudflap and eat the lining in his tank. In our stock bike we just run regular pump gas and we don't have any trouble. Of course we run the gas out of the bikes so fast it doesn't really matter. My brother on his 70 runs a tank a week.
    Jul 2012
    Joplin, MO
    597
    It makes no difference. The best gas to run in that would be ethanol free.
    The 110 won't hurt anything but your wallet.
    Oct 2015
    Polk City, Iowa
    27
    Just had the motor redone, but it's stock. Bored out just a hair. I didn't know if there was a higher energy potential in 110 octane gas than 93, in addition to the extra resistance to combustion.
    Is airplane fuel still leaded? Would that hurt the reed valves?
    Williamstown PA
    5,825
    Your just wasting money. Run 93. Its a stock motor.
    Apr 2014
    Edmond, KS
    2,591
    If I recall correctly, the higher the octane rating, the slower the gas burns. The reason that it's used for high compression engines is to reduce detonation. If you use 110 octane gas in a stock compression engine, it won't run right. I have a friend with a stock '06 trx450r. His oldest daughter's boyfriend borrowed it one weekend to take to the dunes. He and his "genius" friends put some race gas in it and it would barely start and run. It would also backfire out of the exhaust. After running a tank of pump gas through it, it now runs just fine. Another friend has a pretty hot Banshee. He tried some 118 octane gas in it once and it would barely pull itself along. He now runs 110 octane mixed 50/50 with pump gas.
    Jan 2013
    minnesota
    5,911
    In general, this was the case many years ago, however, it is not so much the case now . . If one emails a fuel mfg's tech department, they can tell them what the the flame speed of the fuel they are interested in is.
    Actually, it will run just fine if it is properly jetted.
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by Kyleiniowa View Post
    Some is, 100 is high lead and 100LL has less lead.
    No.
    May 2011
    eden,ny
    3,481
    Av gas is 100 octane and leaded.runs great in my tecate but it has a high compression dome and was jetted with it.
    Oct 2015
    Polk City, Iowa
    27
    Maybe you can help me with my understanding of octane rating... I thought it was a measure of the resistance to combustion? Wouldn't that be more of an issue with the compression being to low or the spark plug not hot enough to ignite the fuel rather than jetting? Or by jetting do you mean like the importance of a proper a/f ratio which would probably solve all of that too?
    Jan 2013
    minnesota
    5,911
    It's complicated, but basically yes.
    No, all gasoline and race fuel will ignite with even an average intensity spark.
    Yes, different gasolines and race fuels require slightly different jetting, this is partially determined by their specific gravity . . Alcohol requires drastically different jetting.
    This may be helpful.
    http://www.capitalcityoil.com/pdf/Th...ing%20fuel.pdf
