I cant seem to get this damn carb to idle steady. Weather has been mild in the 20's at night and 50's in the day.
I have a clean air filter. Good flow on vented gas cap. Carb was thoroughly cleaned inside and out. I checked all the boots for air intake and no rips or holes. Stock jetting. Stock settings. Only thing left I can think of is the air intake where it mounts to the motor. Last time I checked that no cracks. I had the same symptoms when I test drove the bike before I bought it. All I did was remove baffle at end of pipe. Same problems after removing baffle. Stock head pipe and exhaust. Is there a way to do a vacuum test to see if this thing is leaking air on intake ? I am tempted to remove the entire air box and boots and go straight off carb with a shorty air filter. Sometimes when I shut it off I can hear a very mild backfire. Otherwise than that low mids and highs it runs like a scalded dog. Let me hear your take on this as I am stumped. Thanks
