I recently became the proud owner of a 1986 ATC 200S engine in a 1986 ATC250X frame. It's a nice solid machine. I got it for almost nothing because it wouldn't start for the previous owner. The machine has great compression and has spark. I cleaned the carburetor thoroughly, including all the jets, and sprayed everything down with carburetor cleaner. I put it all together and pulled it over and over with no results. I took out the spark plug and it was hopelessly fouled. Like jet black. I cleaned the plug and put it back in and pulled it over and.... it started!!! For about 3 seconds and sounded great. It didn't smoke or anything either. Then, it shut off as fast as it started. I pulled the plug again, and it was black. I cleaned it, put it back, and started it for another 3 seconds or so, then it fouled the plug again. After fouling 6 or 7 plugs, i pulled the carburetor off again and checked the fuel mixture screw. I tried to turn in the screw to count the turns, and found it was turned all the way in solid. I turned it out a turn and a half, and reinstalled the carburetor. Now it won't even burp or anything. I clean the plug, put it back, pull it over, take it out, and it's jet black again. I've tried a D8EA and a D7EA, plugs. Sorry for the long post but PLEASE help if anybody has any ideas. P.S. I don't know if those are the right plugs, they just came with the wheeler. Thanks in advance!
