Thread: 250ES Big Red 5th speed slippery
    Dec 2015
    Québec, Canada
    Hi! I bought a 85 Big Red and I'm new at this forum!
    I have to solve a problem. The automatic clutch does it's job, except for the last speed... When I shift up to the 5th and go WOT, the motor revs to high for a moment, so I release a little bit the lever and then the motor revs down with the wheels.
    Some ideas? what can I check?
    Thank you!
    Dec 2015
    Québec, Canada
    .........ttt
    6,811
    Adjust the clutch first and see if it helps ?
    Might be time to replace the main clutch .
    ac10 is offline New to the board Arm chair racerNew to the board
    Nov 2015
    manitoba Canada
    12
    Quote Originally Posted by SuperCarlus View Post
    Thank you!
    .................try keeping your foot away from shift lever after you shift to 5th gear....your foot could be the problem..or your shifter is not springing back..does this only happen in 5th gear?
