Results 1 to 14 of 14
Thread: Need help with fuel pump
    Oct 2008
    Reedsport Oregon
    856
    I have a vacuum operated fuel pump on my zuki 185. i rebuilt it but it still has issues (can see it has trouble keeping fuel in line through clear fuel filter) is there a aftermarket pump thats vacuum operated i can use? theres no new oem available and ebays used ones are junk, i tried one already.
    any help is appreciated, my bike runs fine if i hold the tank above the carb and let it gravity feed without the fuel pump system...
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    Oct 2008
    Reedsport Oregon
    856
    i forgot to state i already put a rebuild kit in it and it did not work.
    Aug 2014
    South Louisiana
    1,915
    Are you sure that the vacuum port isn't clogged and that it is pulling a suficient vacuum?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Oct 2008
    Reedsport Oregon
    856
    Quote Originally Posted by Jmoozy27 View Post
    yes, wish it was that simple, just need to find a different pump altogether, the zuki one is obsolete
    Mar 2007
    Texas
    5,045
    well what if you took it off and went straight to the carb from the tank?
    ________________
    https://www.mikesatvfix.com
    Aug 2014
    South Louisiana
    1,915
    Or just got a different tank and petcock that doesn't require the pump.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Apr 2013
    snyder texas
    456
    These tanks are below the carb by the right rear tire. Wonder if a mikuni like is used on a race kart could be used ??
    you know whats right therefore you know what is expected
    Oct 2008
    Reedsport Oregon
    856
    tanks too low to eliminate a pump
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    Fuel pump for an FL250 may work
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    Oct 2015
    Chapman KS
    30
    early Kawasaki KLT250's had vacuum pump before they went to electric. part # 49040-1002 most places say obsolete but i was able to find a few searching. might work?
    1978 ATC 70
    1978 ATC 90
    1984 200 es Big Red
    1984 200x
    1985 250sx
    1985 350x
    Mexico
    9,018
    One of these should do the trick.
    http://www.ebay.com/itm/Genuine-Miku...tWbsUq&vxp=mtr
    Oct 2008
    Reedsport Oregon
    856
    Quote Originally Posted by el camexican View Post
    awesome, thanks!!!!! Good lookin out im ordering it right now!!
    Feb 2015
    Cairo NY
    55
    A briggs and Stratton pump, like the vanguard v-twins use, may work too. Every mower dealer should have them, tho that mikuni looks better. I just put one of the briggs pumps on an onan powered welder- using just crankcase pulsations, it pumps well, and the pressure is not too high like the aftermarket electric pumps would be.
    NEPA
    7,051
    The one El posted will work. But be sure you have the vacuum line and fuel line routed UNDER the frame rail. A lot of guy srun them accidentally on top, put the seat on,wala, no fuel. Popular mistake.
