Results 1 to 15 of 21
Thread: Leaking gas tank 86 big red 250
    Feb 2015
    Spokane, Wa
    50
    Hey guys I found a really nice tank for my big red but it's leaking on the rear bottom corners on both sides. I heard red coat or kreem would work but not sure which will be the best. Any ideas? Thanks for your input.[ATTACH]undefined[/ATTACH]
    Attached Thumbnails Attached Thumbnails 20151208_221429.jpg   20151208_221457.jpg   20151208_221347.jpg
    Apr 2008
    NW, IND.
    842
    https://www.kbs-coatings.com/ Look under tank sealer,Good Stuff.Made in the USA.
    80' Honda CR80R
    78' Honda XR75
    77' Honda CT-70
    74' Honda CT-70
    75' Yamaha GT80 Enduro
    76' Kawasaki KZ900
    73' Kawasaki H1-500
    76' Kawasaki H1-500
    Pacific NW
    4,255
    That is such a cryin' shame with suck a pretty tank.
    Some radiator shops will fix 'em too.
    I had one that was drained but left with the cap on.
    You could easily fit 4 fingers through the bottom of the tank.
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Had two tanks done at local radiator shop with red coat . one just needed sealed , the other brazed up and sealed . Both with Red coat .
    wellys88 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2015
    WA
    194
    have it properly repaired either brazed soldered or welded, seal coat has to be done right and isnt a permanant fix
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    Use redkote..... It is a permanent fix.
    Nov 2012
    Buffalo, MN
    427
    NEVER use kreem! That stuff is junk no matter how good it's done.
    May 2013
    St. Louis
    505
    That is Red-Kote for anyone who may be searching for it. It's not British.
    http://damonq.com/Red-Kote.html
    Ok , I mis spelled it smart ass . Go urself
    Mar 2013
    Central PA
    2,362
    Quote Originally Posted by Chopsaw View Post
    Come on now, that was pretty funny.
    Red coat. Get it? I guess not lol.
    Nov 2015
    WA
    194
    Quote Originally Posted by shovelryder View Post
    use redkote..... It is a permanent fix.
    no its not, not by itself. the hole has to be properly repaired first, then use redkote
    Nov 2015
    WA
    194
    Quote Originally Posted by Ghostv2 View Post
    ahhahahah that was funny ghohstv2 lolClick image for larger version.
    Apr 2002
    s.w. michigan
    6,498
    I used a material I am VERY familiar with in making parts on somebody's rusted seam leaking trike tank several years ago and it worked beautify.
    Tape the outside, mix the resin and pour. It is gas proof. To hard and can cures way to quick for me to make Tri-Z top mount tanks from but it is what we make our replacement Tri-Z water pump gears and tecate water pump gears from.
    If you do end up giving it a try, pm me. I have sevral tips on using that will be helpful.
    http://www.hobbylobby.com/p/22272
    john
    Nov 2012
    Buffalo, MN
    427
    Quote Originally Posted by wellys88 View Post
    Been using it for 15 years. Red kote is a permanent fix for pinhole rust leaks. You pour it in and let it cure and nothing will touch it. My last SX had the same holes as his but worse, and it's still ridden weekly by my cousin that bought it from me.
    Nov 2015
    WA
    194
    Its not a permanant fix, the metal will eventually rot and the sealcoat will fail, EVENTUALLY, it is NOT a permanant Fix, and if you open you eyes and actually look at teh picture there is a quarter inch size section of his tank that is swiss cheese from what you can see, its far from a pinhole, but I guess by your logic, Redkote is the be all end all of all tank problems and if he uses it he will NEVER EVER EVER have a problem again
    Nov 2012
    Buffalo, MN
    427
    yes. That is my logic. I'll stand by it, as will anyone who has properly used red kote. I'm done now.
