I'm restoring a 86 125m and my seat foam needs replacing. As for all 2nd gen 125m 's parts are hard to come by. Does anybody know if a seat foam off another model is similar, or maybe one off a later model fourtrax 125m is compatible? Thanks.
Did this search a few years ago and the closest foam that I came up with was the 200s .
Thanks for the reply. Is the 200s foam what you ended up using? If so how did it work out? Any modifications to the foam?Thanks
I believe the difference was in the length and width at the back , had to do some trimming but it worked just fine .
Thank you very much the information.
