Thread: front tire alignment.what gives
    Dec 2015
    ontairo.kitchener
    11
    ok so i put one of the two 125 tri motos together.just to see what it looks like after powder coating frame forks rims bars .
    .body work painted up .bit of a bugger to do but we are happy with it .back tires installed .now the newbie question.the dang front tire is closer to one fork then the outher .what is with that.is it normal. or did we screw something up .help.
    jonolanracin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    west tenn
    319
    If the hub doesnt have some type spacers on it id think maybe rim is mounted to wrong side but i cat say for sure without a pic or more info
    Dec 2015
    ontairo.kitchener
    11
ID:	225314 Click image for larger version.
    ok so spacers are the same ive rotated it .ive flipped the hub. im thinking of takeing half inch of one spacer.and adding it somehow to outher side .looks like it would work just dont wana mess with it.the tire and rim cane from a 175 .could this be the problem. are spacers different on 175 then 125
    May 2011
    eden,ny
    3,481
    Is it a rear wheel ? I know the 225's used a different front wheel than on the rear. About 3/4" difference in the offset
    Dec 2015
    ontairo.kitchener
    11
    problem solved .machined a new set this afternoon.made one 3/4 of an inch longer and shortened the outher by the same ..dont know if thats the right thing to do but it worked great .wheel is centered perfect now and solid. so it works for us .teat ride was perfect.thanks for your help all.
