You put on the gussets and then chopped out the bar.
If the plan is to strengthen the frame, then get it back in there.
I'd just move it up higher, grind it to fit well and try to get a nice weld all the way around it. You gotta be safe.
Even if your not much of a jumper, a CR125 is. And a stuck throttle may show you the week spots.
That flux wire looks like it's just putting blobs of melted wire on there, not real good penetration.
I wish you had a gas mig welder; They are very easy and when welded well, the welds are strong......
