Well I'm in Minnesota, 4 days ago it rained then froze and it has, like it has done multiple times in the past, froze the electric on/ off switch, it needs to be coxed a bit to get it to turn, well this time the throttle froze also. I put a little pressure on it and it opened the throttle and got stuck , Revved up a bit but I turned it off and gave the throttle a little more pressure and it opened completely but got stuck wide open(it wasn't running at that time) , So I pushed it into my warm garage and it thawed out and the throttle moved back to where it is suppose to be, so the throttle moves back and forth but it won't start it just pops and then smells like a lot of gas. I'm thinking maybe the Throttle is still stuck. So I'm going to pull it apart , but I just want to know what I should be looking for and if I should worry about small parts coming popping out
