Thread: So the timing chain can "stretch"?!?!?!
    Nov 2002
    1,189
    Is this true? I tore the 110 apart to get it ready to sell, yup im gonna, well the timing chain is looser than a son of a gun, but the tensioner won't go more. My uncle said that when it stretches, it makes the timing go off, so it doesn't run as well. I would notice that the throttle respnse would change dramatically when accellerating and deaccelleration, then to accellerate.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    Houston,Texas
    1,044
    Yes sir,any chain can stretch.It sounds like you need to do a top end rebuild,but you are selling it...I'm sure you can find someone who is willing to put some labor into it.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Nov 2002
    1,189
    Im fixing a lot of the small probs, like the stuck drive chain, which i just fixed, and the loose timing chain. I have about 4 other 110 and 90 motors to take from so i thought i'd fix it up a bit, then probably get some more out of it. The motor only needs a bore now. Ive fixed pretty much everything else over the years.
    My Rides
    Yamaha 200E
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Yes, the chain can stretch and if it is too loose it can skip a tooth which will result in bent valves. I would keep that in mind if you leave it alone and sell it to someone. That would be a real bummer if you buy a new toy and it breaks right aay on them.
    Good Luck!
    Dec 2003
    Germany
    94
    hmm... i never got that deep in the engine of my 200X yet....what happens if the chain is getting to loose?
    I mean how can i tell that it`s to loose?
    Nov 2002
    1,189
    usually you can hear it if its too loose. It sounds all ratchety and like riding on a roller coaster when it is being towed up
    My Rides
    Yamaha 200E
