Thread: 84 atc250r oil
    Jan 2004
    28
    84 atc250r oil
    how much should i run on the clucth and what viscosity
    Apr 2002
    s.w. michigan
    6,498
    oil
    0.98 u.s. quart or 1.2 quart if you done a complete motor over haul.
    i just poured in a quart of 30 weight.
    there is a bolt under the filler hole,,, my book says to put oil in the trike untill it starts coming out the bolt hole.
    john
    Jan 2004
    15
    it depends on where and how hard you ride it but i would put a thicker oil than that in it.
    m/m
    Nov 2002
    1,189
    Actually, if you go to high, the tranny wont shift, and it will slow you down since it wil cause to much drag. 30 wt. sounds good, but don't use gear oil in the 80-90wt range. It is like honey when cold.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
