Results 16 to 30 of 67
Thread: ATC 110 build
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    Thank you Joseph, I found a set of BAPP ones but I may go with your find because they are a little bit cheaper than the BAPP set.
    1979 Atc 110 helm and son
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1988 XR 200 bored 40 over,
    Atc 200x bottom end.
    San Marcos Ca.
    714
    I have some !
    * 1970 US90 Red
    * 1985 ATC 200s
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    The bolt set will be used on the motor that has the polished cases. I'm still gathering parts for it. I will be using plastic fenders that are in really nice condition no cracks. I have a tank but it needs redone. So I will be using my tank off of my 77 90 for now. Pm sent to you Jwheeler.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    I have some more parts coming and I got this modification started today. Yesterday my stage 1 cam arrived, and I have a sl 90 counter shaft coming. What you guys think of the case?
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    May 2007
    Coshocton, Ohio
    1,815
    Looks good to me. I have a case that I cut down like that. I just need to find the right cylinder so I can get mine put together.
    Appalachian American Racing
    the home of
    May 2013
    Brownsville, Tn.
    1,271
    Quote Originally Posted by 1979atc View Post
    Looks Good. All you need to do is just a little finishing on it and you'll be good to go. You can fill the holes with two part expoxy. I use a belt sander to smooth everything up.
    I am the master at removing the Hi/Low gear box. lol
Name:	quick change1.jpeg
ID:	228197 Click image for larger version.
Name:	quick change2.jpeg
ID:	228198 Click image for larger version.
Name:	quick change3.jpeg
ID:	228199 Click image for larger version.
Name:	quick change4.jpeg
ID:	228200 Click image for larger version.
Name:	quick change8.jpeg
ID:	228201 Click image for larger version.
Name:	quick change9.jpeg
ID:	228202 Click image for larger version.
ID:	228203 Click image for larger version.
ID:	228204 Click image for larger version.
ID:	228205Click image for larger version.
    * Nicholson 500 Race Bike *
    May 2013
    Brownsville, Tn.
    1,271
    Another thing you will need a different seal for the SL counter shaft. The one for the Hi/Lo will not work. I think the correct seal is the same one used in a CR250 IIRC.
    I think this is the one you need.
    http://www.ebay.com/itm/Nos-NOK-AE10...BVzody&vxp=mtr
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Ok thanks for the information Joseph, I will get one coming.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    My counter shaft and case bolts came today. Is this the right shaft? And it has 23 teeth on the gear. Thanks
ID:	228252Click image for larger version.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    I did some test fitting to see if the shaft and everything worked. It did, now I'm waiting on my counter shaft seal for the sl90 shaft. And then the bottom end will be ready to got together. Had some bearings for my crank and transmission shafts so I'm all good to go. My piston rings should be coming here sometime. Then I need to get new wrist pin clips then we're all good.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    May 2013
    Brownsville, Tn.
    1,271
    Shaft looks right. Just transfer all the gears from the standard 90/110 with hi/lo over to the sl shaft.
    Pick up a clip from the local hardware store to hold the sprocket on and you'll be good to go.
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Do you think I should get other sprockets? I have one and it's a 11 tooth. I have a clip set should have one that works, and swapped gears to sl shaft and everything worked out. I will be putting bottom end together when my shaft seal comes. Thanks for the help.
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
    May 2013
    Brownsville, Tn.
    1,271
    I am pretty sure you can install the seal from the out side if you want to go ahead and put your cases together.
    Also the front sprocket all depends on your rear sprocket rear tire size and engine mods. A good middle of the road front is a 13-14 tooth. Smaller the front equals more low end bigger the front equals more top.
    1979atc's Avatar
    Jun 2015
    NW Ohio
    213
    Ok thanks I will see if I have other sprockets somewhere. Today must be my lucky day, my seal and my rings came today, only thing I need is a shifter shaft seal. Turned out that one was bad and those are common to leak when worn. I will be ordering one of those. But I can still put the bottom end together, I need a head and I have a 90 motor that needs a lot of work, could I use the head off of it?? I plan on porting it anyway I just didn't know if they were the same as a 110 or not. Thanks
    1977 Atc 90
    1980 Atc 110
    1984 Atc 110
    1985 Atc 110
  15. #30
    6,811
    81-84 250r sprocket seal works perfect as well
    Quote Originally Posted by Joseph Farrow View Post
