Results 16 to 30 of 32
Thread: 200S Confusions
    Jan 2011
    Choctaw, OK
    2,755
    Oh and the mounting pads are 4 bolt
    Scootertrash's Avatar
    In the sticks
    4,638
    I have an 84 200ES in my garage I'm working on for someone. I'll measure it up when I get home and let you know what I find out.
    ATCT is offline Just Too Addicted Arm chair racerJust too addicted
    Dec 2005
    Phoenix, AZ
    709
    Here's a Big Red fender you might want to check out. http://www.ebay.com/itm/82-84-Honda-...hWlavK&vxp=mtr
    1984 Honda ATC250R
    Tionesta, PA
    5,747
    Sounds to me like the front end is an ATC200 (the non-S model). Everything I have seen in this thread points to it being said model. Look it up.
    In the sticks
    4,638
    What exactly does the "S" designate?
    Jan 2011
    Choctaw, OK
    2,755
    As far as I know, the S doesn't mean anything other than a model marketing thing. This thing is obviously hobbled together. The frame is a 200S frame but right now my focus is identifying the front end. The front fender I was trying to put on it was off the other confirmed 84 200S and it doesn't fit. The link ATCT posted shows a fender with side tab mounts so that's not it. This front end has top mount pads that are 10" apart. The 200S fender is at 8 5/8". You can see in the pic how the fender mounts are inside of the mounting pads. When I got this thing, there were 6mm bolts that were welded to the inside of the mounting pads so the 200S fender would bolt up. I cut those off and pressed on not realizing the fender was right but the forks were wrong.
    Attached Thumbnails Attached Thumbnails 100_2496.JPG   100_2497.JPG   100_2498.JPG   100_2499.JPG
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    Jim I'm geussing its 200m . Looks like its an oil filled front end , so its not e or es . The " S " was a sporty version of the regular 200 / 185 which was a larger machine with bigger tires and a non shock front end .
    The parts that bolt on a 200m front end , as far as I know only fit a 200m , like the fender , rack and headlight guard .
    May 2013
    St. Louis
    505
    http://www.hondaparts-direct.com/OEM...M3EAF14VM3E04B
    Looks like 200m . Note the two eye lets at the top of the triples .
    Link takes a bit to load .
    Oct 2008
    NB, Canada
    852
    What size tires are on that machine with the wider spread front end, and leading axle? That wider front end is off an '83 ATC200 (no letter), or an '84-'85 ATC200M, and should be running a 25x12x9, while the narrower one should have a 22x11x8.
    The 200 big reds had a little different forks, plus the different tabs for the headlight guard and front rack.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Jan 2011
    Choctaw, OK
    2,755
    If somebody has a 200M, could you give me a rough measurement of the fender mounts across the front.
    Jan 2011
    Choctaw, OK
    2,755
    I must be getting old or something. The front wheel that was on it is a 25x12-9. The backs are 22X11-8. I already bought tires so now not only do I have to find a front fender, I now have to buy a 22" tire that fits a 9" rim. This thing cant leave my garage fast enough.
    Jan 2011
    Choctaw, OK
    2,755
    I have pretty much concluded that this front end is a 200M given the fender mounts and front wheel. Now I don't know what to do. I could cannibalize the front end off the other 200S sitting here but then I would be stuck with the 200M front end facing the same problem later. I've already blown the budget on this thing so spending another couple/few hundred bucks on a front end isn't an option. This thing really is a frankentrike...
    In the sticks
    4,638
    I may be in need of a front end for the 84 200es I'm working on. The original front end is beyond repair. I need to talk to the owner and see how he wants to proceed. I've read here that the 200m front is a direct swap for the 84 200es.
    I will try to pm you tonight, I'm super busy right now, but I will pm you by the weekend. Maybe we can figure something out that will work for both of us.
    May 2013
    St. Louis
    505
    200m front end is a upgrade swap for the es . Be aware that you need it all . The 200 es parts will not bolt up to it .
  15. #30
    In the sticks
    4,638
    FlyingW, I sent you a PM.
