Results 1 to 15 of 17
Thread: 200es for log skidding/hauling
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Hey, anyone use their 200es or 250es big red for log skidding/hauling? How well does it perform in wet kinda swampy land? Of course it depends on the tires so what tread should I get? I have knobbie tread tires, how do they work for muddy land while hauling logs? I'm thinking of finding work that includes cutting and hauling small - medium sized trees as a part time job.
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Jan 2011
    Brazil, Indiana
    2,087
    They dont drag very well. You should look into a log rite skidding arch. It lifts the weight of the log off of the ground. Even with a small trailer with 1/4 rick of wood on it my 250es is hard to steer when the ground is slick.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Chopsaw is offline Just Too Addicted Arm chair racerJust too addicted
    May 2013
    St. Louis
    505
    I use both a 200es and a 250es to haul wood , drag trees . I like the 200 because of the low range . Both do well , but I'm not trying to make time or money doing it .
    kiser's Avatar
    Coshocton Ohio
    525
    I agree with Hoosier on this one. I pull a 4x8 trailer behind my 250es. I can haul about half a truck load of split and stacked wood in it but the bike don't like it if there is much of a hill. I move the wood forward or backward depending if I'm spinning or can't steer. If it's muddy I'm basically hosed even with Bear Claws. They will only do so much being 2wd.
    May 2015
    1,081
    Wow, sounds like I need to use my Polaris sportsman 700 then!
    May 2015
    1,081
    Even with low range?
    Jan 2011
    Brazil, Indiana
    2,087
    Low range does nothing for your steering.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Oct 2008
    Reedsport Oregon
    856
    the sportsman is going to "work" better if your trying to make money.
    the 84e has reverse at least.
    my alt 125/185 have same problems hauling as listed above but also run out of power up a hill if I have a big load
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    you need a suzuki lt 250 4x4 or 300 4x4 very strong made for work with very low gears and diff lock and can be bought fairly cheap. theirs no other atv out there with gearing like it at all
    May 2015
    1,081
    Quote Originally Posted by honda4h View Post
    Had a 80's Suzuki 250 2wd quad. Freaking thing caught on fire and I said "well done trying to make it run again" what year were you talking about?
    May 2015
    1,081
    what if i put a chain on the front tire for steering
    Jan 2011
    Brazil, Indiana
    2,087
    Quote Originally Posted by AK47KID View Post
    If you put acouple hundred extra pounds on the front you might be able to pull another 4 feet of log.....
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    fingerlakesny
    2,834
    I use mine a lot but the ground is usually dry or crusty snow covered and I pull down hill or on the flat ...
    250r dust runner
    Jul 2015
    SW Oregon United States
    145
    Putting a chain on just won't help. It's a combination of weight on the back/no weight on the front/going uphill around a curve and you are @@@ked. That said, I do haul small loads with a wood pallet on a short chain....but I'm just a broke gold miner with few resources...HA!
    Nov 2006
    southern oregon
    2,338
    I keep dreaming about a trike built just for pullin.. I would extend the frame some on a chain drive hardtail like a 200E or 200M. No suspension to unload and a low CG. Swap in a bigger engine with reverse.. 300ex maybe.? Or whatever that would fit?
    2-stroke lover
