Results 1 to 3 of 3
Thread: Yamaha Zinger Differential question
    Dec 2015
    Ohio
    5
    I know I am new here and I'm sorry if I am looking for advice but I could really use it. I hope in the future there is more I can contribute to this site so here's my question. I have a 86 4-zinger I bought in parts. I found most of the parts I needed on Ebay (and paid dearly for them) and am now stuck on the rear end. There is a spacer between the rear differential bearings That I am missing (I think) at least thats what the diagram shows.
    http://www.3wheelerworld.com/attachm...&thumb=1&stc=1
    I hope this upload works and maybe someone can help me out. #8 is what I am missing. Is this part necessary? The bearings press into the housing and this goes between them.It seems as it may not be needed but I do realize when things are designed they are designed with extensive research and this is most likely an important part. Thanks a lot for any help...
    jonolanracin is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2006
    west tenn
    319
    The spacer is what keeps bearings apart and lined up im sure its a neccasary part if you cant find one i have a parts zinger i maybe able to help
    Jul 2015
    W.PA.
    41
    Yes, you need it. It rides against the inner ring of both bearings so that when you torque the axle nuts you are not putting a huge preload on those inner rings that would cause bearing failure.
