Results 1 to 15 of 24
Thread: Titanium Valve spring collars (Worth it ?)
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    321
    In my current build (It's clearly out of control for what it is intended) I have ordered Hi-performance valve springs from Webcam, but I got just the springs, didn't notice that I did not order the titanium collars> On a 200x would the titanium collars have any impact on general trail riding permanence? my assumption is no but I would like to check to see if it is a strength issue, I don't want to build a time bomb.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
    6,811
    I have never seen a stock 200x collar break or fail but the titanium ones might be an ounce or so lighter .
    Sep 2005
    MICHIGAN
    2,027
    I worked at a valve spring manufacturer that made Nascar and Pro Circuits 4 stoke racing along with Isky and Manley stuff, ect. The real concern is when you step up to heavy duty springs that are hard as fk (around 65 Rockwell C), is the other components like caps are soft and wear and valve stems are weak,soft, and break and bend (and even cam lobes issues for stiff springs). After we advanced our springs to another level the suppliers of caps and stems had to change there products to cope with our springs. We also would hand grind the tips off so they would not dig into cap and themselves. The result changed the power and rpm one could achieve in the world of 4 stroke motorsports and V8 Nascar and so on...
    I helped with order of operations for heat treat hardening (austenitizing), sorting by free length, grinding, heat setting, then finish grinding material allowance, and finally standardized programming for the grinders based on wire diameter. Then along with the micro finish shot peen operation the Engineer they hired came up with to the operations, it changed the face of Nascar motor power output. They tried to act like it was some black art but eventually from experience I was able to reverse engineer some of their formulas and realized it was just standard spring formulas you could find in the Machinery's Handbook.
    They never listened to me about keeping the free length batches separate after grinding for heat setting to make more consistent load ranges. They would pick 3 springs out of thousands to set the oven, but would not measure free length beforehand to determine the top of the bell curve roughly. I tried to push that with the operators cause they would heat set hundreds of parts just to find out the load was wrong when they came out the oven and then they would have to change temp and re-work them again. Waste of time and money. Simple solution but lots of lack of knowledge and understanding and laziness and being set in their ways. Also I think my supervisor liked to try to steal my ideas as his own.
    86 T3
    84 T3
    86 KX250
    Oct 2013
    Wherever I May Roam
    3,757
    Are you running a high performance cam and piston as well?
    Jan 2013
    minnesota
    5,911
    Quote Originally Posted by RUNMEDOWN View Post
    Not a noticeable one . . the lighter the parts on the valve side, the higher it will rev if all else remains the same . . in general, you gain around 50 rpm for every 30 grams you remove from the valve side of the rocker arm, however, oddly enough, you gain very little when it is removed from the lifter side.
    i would only be concerned about them breaking if you have spring pressures of around 800 lbs with the valve open and rev it to 12,000 rpm . . tool steel retainers will exceed those limits.
    the sharp ends of some springs can gouge ti as nd4speed mentioned.
    Jun 2006
    Omaha Nebraska
    321
    Yes 10.25:1 piston, XL185 cam (form a '79)(longer duration/higher lift).
    Jan 2013
    minnesota
    5,911
    in general, longer duration will raise your entire rpm range so it will have less bottom end and more top end which is generally undesireable in a trail bike unless you run it hard, so you may have to change gearing
    Oct 2013
    Wherever I May Roam
    3,757
    In my opinion that combo will be fine for a trail bike since he is raising compression as well. The xr185/200 cam is not that aggressive compared to say a webcam.
    Cooling will be your next hurdle if you plan to dawdle on the trail with it.
    No the titanium retainers are not worth it.
    Jan 2013
    minnesota
    5,911
    Yes, please don't dawdle with it on the trail...or in any other public places!
    Jun 2006
    Omaha Nebraska
    321
    I have the Cylinder off right now to get it board out to take the new Weisco piston, I had to remove three of the lower fins on one side of the cylinder to clear the electric starter from the 200e, I have been reading articles about surface area and cutting additional slots in the cooling fins at set intervals to increase the cooling effect, I almost have it drawn up. I also have a vented number plate (Removing headlight) and the larger Maier tank fins to help direct more air over the fins when I am moving, and I have switched to a 205r front fender that has a smaller down-section to reduce the amount of air being blocked. Other than encasing the cylinder head and making it a water cooled cylinder; I don't think I have much more that I can do.
    Jan 2013
    minnesota
    5,911
    Sure there is, you can extend the fins by simply welding additional material to them . . the more surface area there is, the cooler it will run at all temps . . increasing air flow only really helps much when the bike is moving at maybe 15 mph or more.
    we had to do this on a few bikes at Kawi including the mighty, fire breathing, KLT 110, because i got the prototype hot enough to boil the oil during testing.
    Oct 2013
    Wherever I May Roam
    3,757
    Oil cooler
    Jun 2006
    Omaha Nebraska
    321
    The other side of my thought is that the old 200e big reds would sit at idle all day and run at low speeds with much smaller cooling fins on basically the same motor and they never had any over heating issues. Is it b/c of the mods that I will have issues?
    Oct 2013
    Wherever I May Roam
    3,757
    200e is about 8.2 :1 compression..less power=less heat
    This is why the x has bigger fins than the regular 200's, they are 9.6:1 stock
    A hot day of riding in the summer will get a stock x hot, let alone a hopped up motor
    Jan 2013
    minnesota
    5,911
    In general, removing material from the fins will make an engine run hotter, not cooler . . its simple physics.
    Please post the articles you read regarding this.
