Results 1 to 3 of 3
Thread: 83 ATC 110 shifting question
    Jan 2016
    Easley South Carolina
    I have had great help from everyone on this site getting me to where I am at now. I wanted to see if anyone had any more advice while I still have the right side cover off. Riding it REAL easy it would shift ok. As soon as I got into the throttle just a little more it would pop out of gear andit would rev up really high. After taking it apart I found the bolt holding the shifter drum was loose and caused a lot of play in that area. I now have it back in there with blue loctite and all it tight again. While it is all open is there anything else I should check out that could be a hidden problem?
    Thanks
    Sep 2014
    Ontario
    10
    sounds like your clutch is slipping. To adjust, there is a rubber cap on side of the engine case
    Take off the ajuster locknut. Screw the adjuster in with flatblade screwdriver until slight resistance is felt, then back the screw off 1/8 turn. Tighten the locknut, make sure the ajuster screw doesnt move put the rubber cap back on.
    if that does not work you may need to replace the clutch plates.
    Jul 2013
    mo
    327
    Pull the lil oil screen and give it a cleaning too.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
