Results 1 to 15 of 23
Thread: Project ATC110 Superbike Build
    Nova Scotia, Canada
    20
    Hey Everyone,
    I'm excited to finally be able to share the progress with my 110 build. It's certainly going to be different than any other 110!
    We spend our weekends at the local roadracing track, so my goal was to create the coolest pit bike that we could. It's a 110 with some superbike styling, some drift car styling. Lower. Shorter. Generally badass.
    There's still a ton of work to do, but I will try to update with progress as often as possible!
    First: A proper street tire/wheel package as this thing is going to spend most of it's time in a paved racetrack paddock.
    Fresh OEM piston. Seems like they're getting hard to find!
    I purchased a small metal lathe pretty much entirely for this build. I spun up this clutch cover guard to make the right side of the engine a bit more interesting...
    Blank bits that I made the oil cooler fittings from:
    Finished oil cooler fittings:
    Fittings in the oil cooler. I picked the cooler up for a couple bucks on eBay. I can't imagine it'll ever get hot enough to need an oil cooler but they look so sweet I couldn't help myself!
    Sent from my iPad using Tapatalk
    Nova Scotia, Canada
    20
    Next up is the top triple clamp. The stock one is big & ugly, and I'm planning on running a motorcycle style clip-on handlebar, so it's got to go. I also need a way to mount the awesome OEM ATC speedometer that I found on another project!
    When you don't have a mill, you must find a way!
    Finished top with the lowered mount for the speedometer.
    I added some false fork tops as I like the way they add to the look of the clamp. They still need some work, but it's a start!
    Nova Scotia, Canada
    20
    Brakes! Let's get serious.
    How much brake do you need in a 1980 ATC110?
    I decided to make a disc brake conversion for the rear, using this brembo rotor sourced from a Ducati 900SS. I cut the stock brake drum apart & welded some tabs on to locate the rotor:
    Making sure where to drill the holes:
    Now the complicated part. For the front brakes, I've sourced two radial mount Tokico calipers from a Honda CBR600RR. I think I can fit both of them in the rims around the rotors from a Yamaha Raptor:
    Need to make some carriers to mount the rotors!
    Test fitting everything on the front axle. I've had to completely design a front axle & fork system to make this work. By far the most time spent on the whole build is in the front end.
    Billet fork bottoms are way cooler than the stock fork. I cut several inches out of the fork anyway, so it's gotta be done! What a headache. I had to spin up the inserts in them so I could remove the axle easier. Seems like the best setup I could come up with.
    As the rear part of the frame has been cut out, it was easiest to spin up a new carrier that I could weld into the frame. The axle is now mounted about 5 inches shorter than stock & 4 inches lower. It needs to be low!
    A quick shot of the rear to show you what the aim is:
    Nova Scotia, Canada
    20
    A couple more for tonight!
    Can't forget about the speedometer drive..
    Test fitting
    Had this stock Ducati 996 steering damper laying around. I think it looks good, no?
    It's starting to come together! I can't get over the look of this crazy thing.
    Nearly finished front hub & fork assembly. Caliper mounts next time!
    That's it for now. More updates soon!
    Dec 2012
    Quebec
    47
    This things is awesome! Nice fab work!
    Feb 2013
    Brazil, Indiana
    728
    That's a pretty sweet 110....
    1979 ATC110
    1983 ATC110
    1984 ATC110
    1984 ATC125M
    1985 ATC110 2 of them
    1985 ATC110 The wife's
    1987 ATC125M
    1985 ATC250ES
    1984 DX225 with 250 timberwolf engine and swingarm. Wolf in DX clothing
    Jun 2009
    Leander TX
    2,217
    Very cool.
    I admire the creativity - it's not in me - I'm just a copycat.
    Jul 2013
    mo
    327
    I have a total 110 erection right now. That thing is crazy awesome!the mods ....man awesome work. Love the turned side case.
    http://www.youtube.com/user/effortequalsresults
    83 atc 110
    77 atc 90
    80 atc 110
    85 200x
    85 200x
    87 250es
    79 atc 110
    1978 atc90
    1985 200s
    1985 atc70
    1983 atc 70
    Aug 2007
    Montana
    857
    Man I love your inspirational thoughts .........Man Job well done ....She is going tobe a cool one thats for sure ......
    DO the Best With What you got !
    My Feed back :cool
    Jun 2013
    Oceanside, CA.
    615
    Some great imagination and machining skills. Wonderful cool project.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    San Marcos Ca.
    715
    Great job !
    * 1970 US90 Red
    * 1985 ATC 200s
    Mar 2013
    Central PA
    2,362
    Since it's going to be mainly on the streets have you thought about ditching the live axle and go with something like on the KLT's? Would improve handling a lot.
    Nova Scotia, Canada
    20
    Quote Originally Posted by Ghostv2 View Post
    That's not a terrible idea. We'll see how bad this one actually turns when it's rolling. I originally had plans to cut some CV axles up & build solid A-arms for the rear so I could run some camber, but put that away for the time being. Would be a heck of a lot of fab work & as it is now it's been about 3 years since disassembly. I pick away at it in the winter time when it's cold as F*&^ outside...
    Oct 2008
    Reedsport Oregon
    856
    great work, ive owned a street legal 200x and can say ghostys idea with the klt axle is a great one.
    mine handled terrible on the street with a live axle, after my experience id recommend a diff too!
    Suzuki ALT 50: Skeeter
    Suzuki ALT 50: full suspension kit: the grasshopper
    Suzuki ALT 125: The Toad
    Suzuki ALT 160: Was a Quad runner 160: The Tri-Runner
    Suzuki ALT 185: The Warthog
    1979 Subaru brat: daily driver almost 400k runs strong
    NEED ALT 50 SEAT PAN
    The Open Road
    4,736
    Nice work. Awesome design.
    I love your endmill-in-the-chuck with the tree on the tool post idea.
    Sent from my Z998 using Tapatalk
