86/87 200x swing-arm needed. can you help?
Whats up all, so I had to take my swing arm off to replace the bearings and after a week of PB blasting finely got the bolt out and now I also need a swing-arm, the left side of the arm that holds the bearing , pivot bushing and seal is all wallered out like a las vegas brothel. So I'm in need of a new swingarm also. There are a couple on ebay but I wanted to see what you all have. I also had to take the rear shock off for rebuilding but the upper sleeve that the bolt goes through was seized on the bolt and had to cut the bolt to remove sooooo I am need of the bolt and sleeve also. any help would be appreciated. Thanks guys.
PM me your phone # and ill call you tomorrow. I have one with the axle and hubs still on it from an 86 200x.
//ArrowChat Integreation Code
