Originally Posted by
Birddog85
It runs STRONG, brakes are good, bearings are good and it has 3 brand new tires and it has 9" 350X rear wheels. The worst part about the whole machine is that someone welded both rear hubs to the axle! WHY?!?!
Could it be that the PO also used the 350x wheel hubs? Their splines are different and larger than 200x making them loose on the axle and they fixed it by welding them. You might find after grinding and removing these hubs that the original axle splines are ok and can reuse original correct style hubs. Some people do stupid stuff....
"HJ"
’84 YT60
’89 TRX250R (stock )
’90 LT500 Quadzilla
