I have a template setup from a member here ordering a race harness for a 350x, and was wondering if anyone else would be looking for one as well. I'm looking to run a batch of 5-10 of them. If you want to vouch that you would buy one (or more), please post below. I attached photos of how theirs turned out.
Looking at $55 each + $3 shipping. I can give a slight discount for more.
Thanks for your interest, I'm targeting to have the run done in 1-2 months to leave plenty of time for the other harnesses I have queued up.
For a push button kill switch, this one should work well or a normal tether one will work: http://www.partzilla.com/parts/detai...0-KZ3-L30.html
Specs about the harness.
- White with yellow stripe wire is not used in the harness, headlight, taillight, and regulator are not used.
- CDI, Coil are wired for OEM location
- Kill switch wiring is a bullet male + bullet female and does not use the hand bar switch. From my understanding this is a common layout for kill switches/tethers. You will need a Normally Open kill switch (open circuit for run).
- OEM colors are used for easiest troubleshooting with a service manual
- 18 Gauge Wire (standard size) and made in the USA
- Wire spec is GXL which is resistant to high heat, oil, chemical, and mold resistance (commonly used in automotive engine compartments)
- Terminals are high quality Japanese
- Tubing is a nice thick yet flexible PVC which is resistant to sunlight, weather, chemicals, oil, and mold
- Terminals hand crimped (B style) Same style as OEM
