Thread: 84 Kawasaki Prairie 250
    Jan 2016
    Wisconsin
    Hey guys, Im Dustin.New to the Forum and new to owning a three wheeler. So I picked up this 84 Kawasaki Prairie 250. (pics later) has anyone done a carb swap. the carb on it is junk.. there's a home made butterfly, doenst like to stay running when the choke is off . anyone a expert on these machines????
    Apr 2012
    USA
    4,129
    Don't really know much about these machines, but maybe a honda 250es carb might work or a honda 200 series carb?
    I'm also trying to locate a wire harness for the same machine that you have to make a template off from. If you would lend me yours I'll make you a new harness free .
    Bliss NY
    6
    I have owned several my carb was never a problem the electric fuel pump can be a pain I ended up running a carb bowl pump and a pressure regulator to get all mine going good
    Bliss NY
    6
    It should have a fake cover where the gas tank normally is and the tank should be over the rear end
