Thread: Runs without a choke installed
    Feb 2016
    Regina, saskatchewan
    21
    So I have a Yamaha 125 and it will start up just fine and idle great but without the choke installed, now as soon as I thread the choke into the carb it dies. It's like it is sucking way too much air from the choke hole.i unhooked the air intake and it is sucking air so I cannot figure this out ! It's very frustrating
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    Sounds like your filter is waaaay plugged?????
    Feb 2016
    21
    Quote Originally Posted by shovelryder View Post
    I unhooked the air intake boot completely and nothing changed
    Apr 2012
    USA
    4,129
    I don't know the yamaha design really, but for a honda if the choke needle was removed, it would add more fuel, which is basically what a butterfly choke does, so I'd say your main/idle jets are plugged, and the only way it gets enough fuel to run is with the choke all the way out.
    Might want to take the carb apart and check it out atleast.
    Another thing to watch out for is intake boot leaks which would make it run leaner than normal, again the choke could give enough fuel to make it run again.
