Results 1 to 7 of 7
Thread: ATC 350x camshaft question.
    Jun 2014
    Lengby, Minnesota
    31
    I'm putting a Megacycle 162-30 grind cam in my 85 350x
    I'm getting HD springs and chromoly retainers
    Also getting 4 new valves.
    My question is...do I have a different valve clearance (lash) now? Or can I just set it to the manuals spec?
    Jan 2013
    minnesota
    5,911
    megacycle should send a card with the cam that says what the clearance should be . . if they do not, call them and ask.
    It's more like .005 and .008, not OEM .003
    Did you have your rockers hard welded?
    Ranvier is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Sep 2016
    Phoenix, AZ
    307
    One year bump! Anybody know if this is at tdc?
    Slidell, LA
    4,738
    Yes, you always set valves when the piston is at TDC of a compression stroke.
    Sep 2016
    Phoenix, AZ
    307
    Thanks. I thought I read that some after arket cams had a different procedure. Here's the card that came with the motor.
    Slidell, LA
    4,738
    Yeah, that card makes sense. All you care about are the last two numbers. .004" intake and .006" exhaust with the piston at TDC on compression stroke.
