Results 1 to 7 of 7
Thread: 185/200s engine
    sandusky, Ohio
    127
    185/200s engine
    What was the difference between the 185 engine and the 200s? Were the stator and all the electrics basically the same? I thought the only difference was the top end but not sure
    Oct 2008
    NB, Canada
    852
    Piston and cylinder I believe are the only difference. Electrical is all the same.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Apr 2012
    USA
    4,133
    I think it depends slightly on year too, wire harnesses year per year are the same for 185/200, but every year the part number changed. Generally like machines can swap stators, you just need the matching flywheel to go with it. This is the same story for a 85 vs 86 350x, stators are different part numbers but can be swapped between engines with the correct flywheel.
    Mar 2007
    Texas
    5,045
    ps2 is correct and so is gearhead.
    you can put a 200cc cylinder and piston on a 185s no problem.
    ________________
    https://www.mikesatvfix.com
    rustyhondas's Avatar
    rustyhondas is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2006
    Missouri
    319
    The CDI plug can be different on the harness,that sort of falls under electrics.
    86 atc 250r
    85 atc 70
    84 atc 200s
    05 650 rincon
    06 400at rancher
    93 lt80
    02 kx65
    Apr 2012
    USA
    4,133
    Quote Originally Posted by rustyhondas View Post
    Even though the CDI plug changed, the CDI's are more or less the same. You just have to use the correct cdi for the harness you use as long as it is on the same type of machine, like 185/200 vs 250r would cause problems because the cdi advance curves are majorly different.
    sandusky, Ohio
    127
    Thanks for the replies great to know. I only have one 185 but I have three 200s' From what I found your all correct. Most all of the parts are the same.
