1982 250r where to find swing arm bearing kit
Hi,
i suppose this is my first official post on here, im working on a 82 250r and am having trouble finding a swing arm bearing kit with the sleeves etc. The old bolt had to be cut out and the sleeves were hurt in the process. I have found the needle bearings alone, but i need the other parts also. Can anyone point me in the right direction? Thanks
Those are obsolete. You have a couple options.
1. Write down each part number you need and try to find them through eBay or dealer inventory
Or
2. Just buy a new pivot bolt, then contact BKM (on the boards) and see if he can make you some delrin bushings. These take the place of all your front components (bearings/seals/sleeves/etc)
Feedback for yaegerb:
Click Here
I have already purchased a new bolt, also pm'ed bkm. Thanks for the reply.
The delrin bushings for the 85-86 250r should fit and work for the 81-82 250r aswell. I know the sleeves are the same diameter just shorter on the liquid r. And I know the needle bearing will fit because Im using the liquid r needle bearings in my 81 250r.
250r rules
//ArrowChat Integreation Code
