Thread: 250sx fuel tank
    Nov 2014
    Jackson, MS
    21
    250sx fuel tank
    I recently purchased another 85 250sx thats in pretty good condition. The fuel tank is beautiful except it has a few small rust holes along the bottom. I cant find anyone in my area that will repair the holes. Everyone says put a plastic tank on it, well, I dont want a f'n plastic tank on this bike. Is there someone on
    3ww that repairs metal tanks or can direct me to someone that does? Any help is greatly appreciated
    May 2013
    St. Louis
    505
    Did you try a radiator shop ? Thats where I had mine done .
    Feb 2016
    Newfoundland
    7
    Acid wash the inside and then use liquid rubber can be done yourself!
    Dec 2015
    East Kingston, NH
    91
    Kreem tank liner kit.......acid wash/etching to desired time frame....rinse with provided cleaner using 1/4 20 nuts and shake out the scale....Using brake cleaner,let dry and clean out where the holes are......use double sided aluminum foil {one side sticky} can be bought at hardware store....use JBWeld to fill the holes and the aluminum foil to keep in place with the tank on level ground....after required setting, remove foil and sand to desired results....You can bondo or paint over the jbweld...The kreem treats the inside of the tank...I've used this method and it lasted 20years.....i'ts all in the prep....Have fun.
    '85 ATC350X
    '85 ATC110
    '85 ATC200X (gone)
    '84 ATC125m (gone)
    '86 Tecate 250 (gone)
    Dec 2015
    Louisiana USA
    30
    Radiator shops in Louisiana will not do fuel tanks/cells anymore, against insurance regulations. Freaking government regulators.
